MingoMowing
I have a cub cadet 2135 with a kohler command 12.5 motor, got it on trade, the issue the guy was having was he said it needed a fuel pump, i added an aftermarket electric pump from auto zone that pumps 2.5-4 psi, it runs and drives fine other than it seems to kill of when i throttle down below 1/3 throttle, do i need to add a return line to the tank between pump and carbureator to reduce fuel to carb? with it killing off below 1/3 throttle it makes me wonder if im dumping too much fuel is why im asking
