I have
YTH20K46 (960450004-05) that when I turn the key on I loose the neg ground to the hour meter. Also motor won't shut off with the key in the off position, have neg charge to coil but is very weak. I have changed key switch and coil same results. I have cleaned the neg points on the frame. Also has new battery. A mouse had chewed the positive wire to fuel solenoid and I replaced that wire. Tractor does run.
