Farmer Mike
- Mar 20, 2014
- 5
I need some help with this. Short history, I purchased this Scag mower brand new 5/07/2010 from our not so local scag dealer. She has been garaged, kept in the dry, never rained on or hosed down. She has been with me 10 years and well kept and only has 152 hours on the meter. It has been pretty reliable. 2012 replaced a relay in ignition box because of no start or no anything. Next issue was at about 100 hours replaced gearbox on top of blade deck. Next event was replace the gearbox again on top of blade deck. It was checked and full of oil when mounted and lasted around 20 hours. 3rd event was replacing it again. 3rd gearbox is still working. Now, for the last couple of months the engine, Kohler 31 hp EFI, almost dies going up a hill, going down a hill or making a left hand turn up or down a hill or just backing up to fast. Last Friday I had mowed 1-1/2 hours and it had been doing all that almost dieing stuff and when I went to back up the motor stumbled,(almost died) backfired and has never started since. I have worked on it for a week now and don't feel any closer to solving the problem.
Here is what I have done or checked; 1- Fuel, Tank is a little over 1/2 full. 2- Battery is fully charged at 12.4 volts. 3- checked 4 fuses, all look good. 4-Have checked every inch of wiring for shorts and cannot find one 5- pulled spark plugs, they are only a couple months old, they look, feel, smell wet with gasoline, crank engine with plugs out no gas blown out of spark plug holes. 6- reinstall with brand new spark plugs, engine is still cranking great but no start or signal that it might. Pulled new spark plugs back out, they appear dry. Placed a light meter probe into each spark plug wire end, lights up when switch is on and then fires rapidly as motor is being cranked. Grounded ,(clamped spark plugs to frame and both are firing great. 7- now seems like maybe its not getting gas. Electronic full pump starts up immediatly when switch is turned on and is plenty loud to be herd, (same sound as always). 8- Took end of gas line off of fuel filter to see if gas was coming from tank, (it wasn't pouring out but was dribbling out). Question, Can the fuel pump be making the normal electrict fuel pump sound but not be pumping gas? Forgot to mention that I had checked all the safety switches and they test good but if this was electrical would the fuel pump run and motor crank so well?
What do you think about this? I don't know what to look at, check next. My dealer went out of Scag business a few years back.
Thanks, Mike
Thanks, Mike
