- Feb 19, 2020
- Threads
- 114
- 12,413
And the 793880 camshaft only has one tiny piece plastic on the ACR. The lobes and the rest on the camshaft is all metal. I know as I replaced enough of them for failed ACRs.
Great so we have a steel cam. Nice find StarTech. Hopefully it hasn't jumped time?And the 793880 camshaft only has one tiny piece plastic on the ACR. The lobes and the rest on the camshaft is all metal. I know as I replaced enough of them for failed ACRs.
StarTech found you have a normal steel camshaft. Forget about a plastic camshaft.Question. I don't know if this engine has a plastic cam but if it did, would the valve clearances at TDC always be correct like they are?
Throttle is surging like a mo-fo in your attached .gif file.
