Need between wiring harness
36racin
Finished installing my new CV742-3022 engine yesterday. Completed pre-startups items. And attempted to start motor. Connections between old engine cv740-0021 and new engine looked the same and plugged like they should have. Turns over, fires but no power to fuel solenoid. So not starting. Without cutting up the new harness for the new motor and voiding the warranty I need another between harness(not sure what its called). Its the small harness between the Scag Wildcat harness and the new engine harness. Can anyone assist with one or part number for new between harness?
Thanks,
Todd
Does your old engine have shut down solenoid on the carb. If you can take a picture of the harness where it plugs into scag and also at the starter where they connect and hook up.
Also what is the scag numbers plus serial number. Also what engine came out of it from the start what wiring harness do you or replaced it with.
71A2DDF6-8C53-4027-9217-EDCFF0786154.jpg88771589-2D29-4459-9DA9-83C6C4D289C7.jpg4655A652-06E4-4EA4-B256-B4B3F1EA82D9.jpg Looks like power for the fuel solenoid and power to starter solenoid off key switch came off same connector on old harness to fuel solenoid and starter solenoid. New engine harness power to fuel and starter come off two different leads.
Pins on bottom of new Red & Green are not used on old connectors. And the green on the old harness is not used at all on either. So really only the red on the new connector needs to be moved...or new middle harness where it connects these pins to the new engine wiring harness
Did you order your new engine from Kohler as a direct replacement engine for your scag or did you just buy a engine. Looks like the engine harness is different from what I Am seeing why I asked. But that does mean it won’t run. Have you had it running yet at all with like an either shot or anything yet. Also I take it you have all safety switches connected and working.
The numbers you posted in the picture is of the cutter deck. We need the ones on the scag itself located near the engine or the rear by the roll over bar mounts or close by the sides of the seat area.
Just used a jumper wire from starter solenoid line to fuel soleniod and engine started right up....Hooray it runs...Now gotta get connected correctly
Looks more like the first picture but my pins are side to side not top to bottom. I believe I can make a simple jumpover wire and accomplish what I need.
