What’s the correct carburetor number for a Stihl FS 38 trimmer
Dufferman
Hi from Canada,
I was gifted a trimmer from a neighbour FS38 and the primer bulb wouldn’t fill.
I took out the carb and everything was gunked up so I want to get a new carb, filter and plug. The carb I removed is a C1Q-S95 but I think it is not the original as I called Stihl and tried to provide a serial number that was partially missing .
The representative said I should try C1Q S186.
My question is. Where can I find the engine mode number so I can properly match the correct carburetor to the trimmer?
Is there a location on the trimmer / engine where the number is located?
There is no stamped 9 - digit number on the belly of my unit
Looking up the serial #:
Product Type : Trimmers
Model : FS38
Serial Number : 261784642
New Product Registration
Dealer must not haved filed the registration......
If your trouble is that the throttle cable end doesn't fit in the new carb, they did a change a few years back, they switched to a cable with a "z" bend.
Hello,
It looks like it has a Zama. Here is a YouTube video of how to clean/rebuild it.
I would try just using carb cleaner first before trying to rebuild it. Just shoot Gumout into the gas lines.
https://youtu.be/7VM6ZAT96o0
Regards
Jeff
I suspect that is the original carb. Found a chart that showed the FS38 with both the C1Q-S95or the S97 carbs. I am sure that number has superceded to a new carb. I have always provided the model number of the trimmer and the number off of the carb and we go from there. I have seen my local dealer pull out of separate book that list the carb number changes,
Model : FS38
Thanks, that is helpful.
I think I will go with the C1Q- S97 carburetor. The diaphragm, primer bulb and fuel filter need be replaced so I will get the entire kit and install
Does your throttle cable have a z-bend like this one?
Other than this issue, any carb will work fine. The different throttle cables are the only issue that may give you trouble.
Here is what is on the fs38 these days, you need the model with the swivel piece.
