Mr. Mower
- Sep 1, 2016
- Threads
- 7
- 253
Well today was my very first time changing the oil & oil filter, spark plugs, engine & fuel filter(s) on my Raptor flip up ZT.
I'm used to doing regular maintenance on mowers, vehicles, etc. but was quite surprised by the process of draining the oil out of a Raptor flip up. Now I don't really know if every Hustler mower or Raptor for that matter has the same process of draining the oil?
But I kinda looked at the process of just draining the oil as quite primitive and ridiculous!:thumbdown:
Plus, to just to make matters more difficult/complicated, the fact that the area around it all is very limited.
First they have you adjust the small very short black rubber tube (first you really need to remove it and make sure it's clean!) to make sure that it is facing down into that cut out hole right below it.
Then they have you unscrew the oil drain nut and this process will allow the oil to drain. The manual says to expect it to drain for a period of around 10 mins.
Now before I actually started (remember this was my first time with this particular type of mower, I used to do my previous one which was very simple) I read up on the engine maintenance procedure so that I will be familiar with what I will be getting into.
When the part came to draining the oil process, well I was just taken aback by it all. So what I did before starting, I have some extra clear tubing that is a perfect fit that inserts into the small black rubber tube and then ran it down that hole below and then cut if off to the point that it would fall and drain the oil into a small plastic bucket that I had laying around.
Believe me, after I started the process of draining the oil, I started working on everything else and once everything else was completed, the oil draining process was the next to last thing that I waited on. It must have been anywhere from 30 mins.-45mins. time.
You see the manual doesn't tell you about any of what to expect. I really can't see anyone just shoving that small black tube through that lower hole then opening that oil drain nut and have all that oil fall onto the axle, trans, etc. and make such a mess!
Plus when trying to torque down the small oil drain nut, the limited small area around it makes it cumbersome to say the least!
As for everything else, spark plugs, oil filter, fuel filter and engine filter well those were a breeze-no problems at all.
Anyway, the rant is over and well just wanted to find out if every Hustler mower models or just the Raptor has the same oil draining process?
Thanks in advance to all those who have posted to this thread.
