HH70 Vs H70 internal parts
Soonerbillz
Hi folks!
I have a Ariens Rocket rear tine tiller which is equipped with a Tecumseh HH70 engine.
The motor has a broken connecting rod I think(I've yet to to tear it down) ... and I looked up the part # 32591C on Jack's site and it shows a new part # 510222 as a replacement part #
The listing shows that part to fit a H70 but does not list the HH70 model
https://www.jackssmallengines.com/jacks-parts-lookup/part/universal/510222
Then when I checked MFG Supply they show part # 32591C to cross over to a part # of 23-6769
That page shows both the HH70 and H70 on the compatible use list.
https://www.mfgsupply.com/23-6769.html
So I am confused which is the real deal correct rod for my HH70?
I am wondering now also about the piston if I may need one for my HH70.. I am thinking the gaskets for the HH70 and the H70 are the same..
Can anyone shed some light on this issue for me?
Thanks,
Scott
FWIW - the H stands for horizontal shaft. The HH stands for horizontal heavy duty (cast iron ).
Regards
Jeff
Thanks for the replies.. but still even looking at the links provided I am still uncertain if the rods and piston are interchangeable between the two models.
Even in the links Boobalo posted.. the HH70 is not included in their respective lists of compatible models for the part #'s
I found this post from a few years ago.. and if you read it you will find this statement..
"H and HH70's were dimensionally the same, but had a 2.750" bore, different stroke, rod, piston...in fact you could even put the 8hp HM80 rod in it with little work.."
THIS, should be your manual, ( O/H ) see page 83 . info on the con. rod .........
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
ALSO : see this listing and ck the con. rod P/Ns in each of the manuals in the enclosed "block"
http://www.mymowerparts.com/pdf/Tecumseh-Engine-Parts-Manuals/Models_HH60_HH70/
Hi Scott,
Try parts tree.com. Click on Tecumseh, then 4 cycle horizontal, once there on the right search box, enter HH70.
Regards
Jeff
Bummer,,,looks like the connecting rod is not available for either H70 or HH70 engine (at least on parts tree.com).
Jeff
Scott, .... you may want to do your tear-down BEFORE ordering your parts, looking at the IPB you might have the "off-set con rod" ..?? and you might need to replace other parts , ( oil dipper, plate, nuts, etc. ) just a thought, but it's a lot easier NOT to have to return, or re-order correct parts, also..
TAKE lots of pics during DIS-assembly, it will save you many headaches, during reassembly just trying to help ya there buddy ! .. :thumbsup:
Hi Scot,
I agree with Boobala,,,perform the teardown before ordering parts. You may find so many other parts that needs replacing, it may be cheaper to get a replacement engine from Harbor Freight or small engine warehouse.
There is a guy on YouTube that goes by the name of 65ford that does lots of small engine repair vids. He said an excellent source of a good used engine are from pressure washers as the pumps fail frequently. Check Craigslist.
Regards
Jeff
