Ronno6
Strike three I'm out.
I put some starting fluid in the plug port and tried to start it, no spit, sputter or any hit of starting.
I put some starting fluid thru the carb with the air cleaner off and tried to start it, no spit or sputter either.
I waited an hour and squirted a little mix gas into the plug port and pulled the starter, no spit or sputter. I tried squirting some mix gas down the carb and pulled the starter cord and again nothing.
Not even a spit like it wanted to start.
I pulled off the starter side and connected my reversing drill with a 1/2 inch socket and pulled the trigger. The little engine turned over dozens of times without a single spit or sputter from it.
I'm almost ready to toss them both out my barn door.
I'm beginning to believe the shop repair videos on the internet, where the guy opens up a long sitting chainsaw and does everything I've done twice, are not really true.
I have repaired four other engines this year without any issues. I replaced the carb on a Honda pressure washer. Replaced the carb on a smaller Tecumseh pressure washer. Replaced the interior governor shaft of a 5K generator and cleaned out the carb on a Troy-Bilt string trimmer. And they all run great.
These chainsaw engines have stopped me in my tracks.
I have a good spark and I have fuel but I have no fire.
What else could it be?
Have you removed the mufflers yet?
