I didn't think I'd ever find a set of new OEM LB wheels!
parkboy
I recently picked up a pair of NOS part number 689072 Lawn boy wheels ($15.49/ea). I put them on my L21ZSNA and I am amazed at how great they work. The capstan drive works very well when paired with the special "soft" rubber OEM tires!
Parkboy:smile:
You found a great deal. NOS wheels are hard to find.
Took me a couple years to find the ones I have.
Any time I run across some good used ones, I hoard them in my stash of parts. They may not be new, but when I drill them out and slide a bronze bushing in them, they roll good as new.
New ones are getting harder to find so buy them if you see them.
Screenshot_2017-06-20-23-05-47.png This is what I see. :confused2:
Edit: Oops, sorry about the tiny image. If you click it, it will open big.
Where do you find the bronze bushings? I'm thinking of doing that.
Thanks
Thanks
I get the bronze bushings at my local Tru Value hardware store. If they are out of them, the local Ace hardware store usually has them. I don't recall what the exact diameter is, but I use a 5/8 inch drill bit on the wheel and the bushings that I buy will slide right in. Sometimes I have to use a soft hammer and a correct size socket to tap them in. Combine all of this with new axle bolts, and you will have wheels that will turn smoothly without excess wobble.
