shiftsuper175607
 - Sep 11, 2013
- Threads
 - 10
 - 1,000
The rebuild parts arrived today so after a nice motorcycle around the area to relax and get my head in order I decided to remove the bearings from the deck and get to replacing them. First one was a bit of a booger bear to remove as it was frozen solid, end up busting the top inner race out, then dug out about 10 years worth of grass from around the spacer then placed a socket over the spacer and tapped down on it with a hammer. That drove the bottom bearing and spacer out the bottom of the deck. All well and good, threw the blade adaptor, small spacer, and other bits in the ultrasound cleaner to de gunk em and then Tom got stupid. When trying to break free the blade nut on the next blade, my hand hit the corner of the blade and I gashed my hand pretty good. Back in the house to clean it up, wrap it up and call around for a tetanus shot at 7:30 on July 3rd. Good luck there. Found a Walgreens that could do it, well $65.00 later I now have a sore hand and sore shoulder from the shot. No more mower work tonight. But the replacement parts look real good. Bearings are not sealed so I will be adding a grease fitting to each spindle assembly.
You all be safe
Tom
pumper54,
That was a good, but sad story.
Are you sure you're from Texas?
We don't call that a cut...that's a scratch.
You didn't ruin any of your clothes did you?
You didn't need a tourniquet ...
You didn't need a transfusion, did you?
