rvalandscapes
Cutting grass doesn't cut it! Most startup lawn care companies try to make money with just lawn care, and figure out pretty quickly that it doesn't pay. Then they try to raise there price and then "don't put down the gate for less than $40", this type of attitude is absolutely destined to fail...sorry! You cannot make money cutting grass because as you expand to pick up more jobs, your overall cost to run the company becomes cost prohibitive. Meaning, you can only make money cutting grass if you are a single man operation cutting a few lawns per week, but it's just not scalable. Keep in mind that it's JUST lawn care and any 14 year old with a lawn mower can do it. The trick is, figure out how to do those things the 14 year old can't do. You cannot charge a premium for lawn care, but you can charge a premium for practically everything else, provided your company has a good reputation, and your standards remain high.
Solution, you cut grass to gain access to quality clients that might want more, like landscaping, hardscaping, powerwashing ect...these other services produce a higher profit margin and enable you to make money with your sell up services. This also enables you to charge LESS for lawn care, not more. Quality customers will eventually have you do everything from mulching to fertilization. If you won't drop the gate for less than $40, you have already failed as a lawn care business, you just don't know it yet.
Mark
RVA Landscapes LLC RVA Landscapes LLC
Mark
