silver1
I purchased a JD STX38 rider in the spring. After a clean up and check out, I mowed my front lawn.
The grass did not exit out the side much and left a trail behind me. I removed the cutting deck(Black)
check it out and found it had a mulch kit installed. I need to remove those parts and install new cutting
blades. I does have one spindle that is starting to wobble. New belt of course, ect.
What is the best part # of good blades to get the grass out with some power behind it?
Thanks,
Silver1
Thanks,
Silver1
