B bckskin2 Active Member Joined Jun 10, 2014 Messages 54 Mar 30, 2015 #1 One place in the manual say first change 50 hours another every 200 hours. Is it first at 50 then next at 250? Has anyone actually remover the top port plugs? They look impossible to reach. I assume it is an Allen wrench? Jerry
M mechanic mark Lawn Pro Community Leader Joined Jul 15, 2013 Messages 7,500 Mar 30, 2015 #2 http://www.dixon-ztr.com/ddoc/DIXO/DIXO2010_USen/DIXO2010_USen__115389927.pdf every 200 hours, see pages 46 & 47, follow steps & purge air from system, be sure to use Dixon OEM filter & specified oil. Hydro-Gear - Single Axle Transaxles - ZT-3100 your transmission Dixon Ultra 52 - Zero Turn Mowers see specifications Hydro-Gear - Learning Center click on purge procedure Last edited: Mar 31, 2015
B bckskin2 Active Member Joined Jun 10, 2014 Messages 54 Mar 31, 2015 #3 This is different from my manual. Where is the by pass valve? Is that the same as the by pass linkage that allows it to be pushed?
