wilburn cox
- Feb 24, 2014
- 107
I have a Montgomery Wards Signature 2000 Elite Mower. Mower was made by MTD. Wards model # is TMO3000A. Serial # 87-000-7837.
MTD cross over model # is 131A670G000.
I have correct owners manual with parts list and all schematics. Over the years I have had the mower deck off several times to replace blade spindle, belts and blades. A problem began, possibly, after removing and reinstalling the deck. The deck lift lever would not disengage the blade safety switch unless I jerked back hard on the lift lever. I removed the safety switch and checked it with OHM meter and the switch was a little iffy for continuity at certain points. I installed a new switch AND still had the same problem.
With mower deck off and the lift lever in disengage position the safety switch works perfectly. The lift lever makes perfect contact with the switch button and continuity checks perfect. I tried this several times, lowering the lift lever then bringing back to disengage position. Works perfect.
My manual says that with deck lift lever in disengage position the deck should move up and forward. I'm not sure this is all working properly. There is a large very strong spring which is 7.58" long that goes from the deck stabilizer bracket and stretches back and attaches to a bracket on the left part of the transmission. Page # 11 of manual shows this forward part of spring attaching in bottom hole of left arm of stabilizer shaft assembly. Page # 27 seems to show the forward end of spring slipping over a rod in the rear bottom of stabilizer shaft assembly.
With deck installed I just can't determine what is causing the problem with the deck disengaging with the lift lever.
Any help will be appreciated and I will try to respond to all suggestions.
Thanks, Red Cox
Thanks, Red Cox
