I'd like to find out the model and year of my toro with a Suzuki 4 stroke. It's got a mikuni carb and it's surges/idle hunting. Also runs rich
is this where the tag should be?Look for the model number on the back of the deck -- possibly under the big plastic part of the bag. It's a decal if it's like my Toros.
would this be it?Look under the crosspiece where the throttle control is located, I have seen some there... Up at the top, where you push.....
If its like mine the sticker was on the back of the deck and is long gone take a snapshot of your trans ill tell you a model num for parts. The 5hp Suzuki rly never changed parts and the older toros just changed trans type everything else is the same
it's not self propelled, doesn't have a blade stop either. but it was $20 :biggrin:You have to take the cover off the top of the trans I can tell which by the pulley that's on there.
