davbell22602
 - Nov 27, 2011
- Threads
 - 152
 - 1,324
I still say its a carb issue.
I'd drain gas tank, clean it out real good. Then replace fuel lines and fuel filter. If it didnt have a fuel filter then add one in the fuel line.
Did that today...
Replaced fuel lines, Cleaned tank, added a new filter (air and fuel), rebuilt carb.... Still done the same thing..... But, as soon as it went dead i jumped off the mower and checked the spark again, and the spark was orange, not blue!
Sounds like coil has short in it or going bad. Check air gap on coil and make sure its .010.
