- Feb 19, 2020
- 82
- 10,416
One thing I would not recommend is the 4 cycle version that uses an oil dipper system. Many may just make it through the first before they burn themselves from lack of proper oiling. Troybilt 4 cycles are one the worst I have seen here. The main problem is that you operate them level and not inverted due to the oil dipper system.
Now Stihl makes some excellent 4 mix trimmers. They true 4 cycle trimmers that use 2 cycle fuel mix. Shindaiwa also make very good 4 cycle trimmer that have oil pumping system via reed valves where they a separate oil tank and uses straight fuel.
As owners trimmers Homelite did make good trimmers but I don't know about the latest models. I have however used the older model quite heavy on the 14 acre farm.
