Toro trimmer 51830
Robw1965
How do I remove the bumper feed head asm??
It appears that you use a hollow grind large flat blade screwdriver to the screw shaft and turn the head CCW if I am see the threads right. Normal flat blade screwdrivers will just cam out.
Now it does looks like you have already mess the slot up though.
