Toro 20095
steveleb
I have a 20095 key operated model. The battery is gone and the key also. the wires to the have been cut off and no ignition switch and it wont start. Is there any of those wires should be connect to start the mower. The two red wires are not connected to anything.
Battery, switch and wires are for electric starting only and have nothing to do with the engine starting or running. You will have to troubleshoot the engine to find out if you have a fuel or ignition problem causing your not starting problem.
steveleb
I sprayed starting fluid in it and it didnt start, but when I tried to start it i heard compression out of the carburetor. Is that normal?
steveleb
I tried a compression check 0 no compression. I was attempting to pull the head and the middle bottom bolt had oil on it. Don't think that's normal. When that happened is stopped and didn't remove the head.
Tiger Small Engine
What model is the engine? How old is it? How did you do the compression test? Sounds like it is a flathead engine around 20 years old. Try to remove the cylinder head and look at the valves, etc.
steveleb
The build date of the mower has 04/09 on the barcode. Compression test was done with a gauge same one I check the compression of my cars.
Look under the rear door cover for the serial number tag. Toro don't list the mower by build date but by serial number range, so you six different serial number breaks to choose from.
But if compression is coming out the carburetor it likely a stuck valve; although can't rule out a hole in the piston and the air is coming the breather tube at the carb.
2009 models have a serial number starting with 29#$XXXX
steveleb
Took the head off and cleaned the head and top of the block off. With a plastic scraper and starting fluid. I am replacing the head gasket and I need to know the torque sequence and how many pounds to torque the bolts. Its a 126T07 4226-B1.
Thanks for your help.
Gearhead1432
My older B&S Service Manual lists the head bolt torque at 140 Inch pounds for 6B through 130000 aluminum engines.
-Cheers
