SCAG Starter Solenoid Testing
JB2
How to test SCAG starter solenoid on Kawasaki engine?
Same as any other solenoid
Jump from the battery power wire to the small trigger terminal , usually a blue or green wire on a Kawasaki engine harness
If you have a remote starter it is the same process but if the solenoid has 2 small wires at the base then you need to power one & ground the other
