Ryobi Weed Eater Pull Start
cl10Greg
Hello,
Wanted to see if anyone had any tips for this problem. Last year my weed eater pull start string got stuck in the pull out position. I opened up the pull start and wasn't paying attention and that tension cable became unraveled. I am able to get it all back in the pull start compartment but when I turn the plastic piece to tension the cable, it always slips off the plastic nub. I am able to get it tensioned outside of the compartment but can't seem get it to stay on the plastic piece while trying to tension it. Any tips?
Without having a rewinding tool most string trimmer rewind springs are near impossible to get back in.
Not sure about your actual machine but th e spring generally sits in a cup which is removable .
The spring is wound into the cup then the cup is dropped into the pull start , spring end down as a unit .
The trick is to get the hooks on the spring to line up with the anchor places .
And it ain't easy .
Ryobi products are deliberately made to be difficult if not impossible to fix .
PArt of their marketing stragity , hake a tool tha is comfortabe & easy to use so when it breaks the owner will just go out & buy a new one.
Also make you actually wound the spring in the correct direction.
They not all that hard to wind btw I do it several times every year.
