Oops! Hit bottom and blades won’t engage
BDRooster
So I bought a brand new mz rambler 42” and it was working great. Noticed it squeeked a bit after first mow and then the unthinkable happened and I bottomed it out when I hit a hole. The blades cut when I started it and I finished mowing but now my blades won’t fully engage. What should I check first? I know a bit but if someone has experienced this before what was your fix?
tobar
Look at the back. there is a belt guide that connects to the engine. Had same issue, everything you see on deck looks right. Blades will still move but burn up belt.
Bertrrr
What exactly are you saying " wont fully engage " ? If it's an electric PTO - it either engages or not - is yours a manual lever type that you engage ?
