skippymud
- Nov 21, 2016
- 12
- 61
Hello All
I have rebuilt an Onan P220G. Shame that the S/N is no longer visible, but I believe it is an earlier model 220 based on some of the parts that OnanParts suggested I buy based on dimensions, etc. See pics
How do I wire this thing to just start and run for test? I'd also like to hook-up the Stator to make sure it charges the battery. For that I'd sure request to know which tabs are what on the Voltage Regulator - Which two A/C lines run to the Stator? Which one is 12VDC out? Also, do I connect the Ignition Module directly to the Ignition Coil +&- as labeled?
Advance Thanks
Ken
Advance Thanks
Ken
