Fish
- Aug 2, 2013
- 11
- 5,132
Thanks!The center sheave moves up and down, giving the rear end a variety of speeds like a 10 speed bicycle. I have been known to give a light squirt of wd-40 there, but since the belt runs on both sides, just a quick little squirt.
I hope to get up on my lift today to look at it. A couple people have suggested that. Thanks for your inputlikely your variable speed pulley is jammed and not sliding
I assume the only way to this is through where the battery sits? Do you have a link for the eBay part?Sometimes if belt starts to fray pieces of belt can get stuck stopping movement. If taking apart there is a fiber/plastic washer on top. NLA but ebay had some in the past. Or match up at hardware store. Had one where roller bearing started to seize. Ebay has pulley assembly if needed, factory NLA.
