Kawasaki FD731V won't start.
bob47907
I have the FD731V on my mower (not original engine). Cutting just fine a few days ago, then quit suddenly and won't start.
So far, I've checked the following:
Gas is good ,
Fuel shut-off is working,
Both cylinders have spark,
Fuel pump is working,
Gas in float bowl,
Good compression in both cylinders,
Air and fuel filters are clean.
I tried cranking ~30 seconds and found both spark plugs wet. If I shoot starter fluid into the air intake, the engine will fire up for a couple of seconds. I disassembled and cleaned the carb; still won't start.
I've check for leaks between the carb & block-nothing.
What have I missed?
Thanks!
hlw49
Is there water in the fuel?
bob47907
Well, I haven't checked.
I think the gas is good because it is fresh and the same I put in my truck and the push mower.
At this point, I might drain the tank and add new.
Thanks for the suggestion!
