2ball
- Jul 29, 2020
- 26
- 132
I have a regular house dehumidifier in my crawl space and it takes care of business perfectly. I have it draining into my sump pump via a plastic hose that comes out of the back of it. It's currently not draining through the hose. It has a small tank on it that looks like a drawer on the front of it. I can't figure out why the old hose does not drain.
I should be able to drill a hole in the front drawer tank and connect a hose to that?
I would use something like this https://www.amazon.com/Joywayus-Con...lpcontext&ref_=fplfs&smid=A1AOZNO078ITBS&th=1
I would put it about half way up the tank, so I can use gravity to get the water to the sump pump and so the tank never fills and shuts the machine off. The new hose run would be 2 feet of less.
That should work right?
