how to remove 614 housing axle shaft grasshopper mower
Keith M
  • / how to remove 614 housing axle shaft grasshopper mower
I have a GRasshopper riding mower that needs the shaft on the rear back tire replaced as the threaded part broke off. I have found a new part on line but having difficult time removing the old shaft. Any help would be greatly appreciated. Part # 4
Can you post what each part number is, so we can see if there is an internal snap ring?
Keith M
We took the back screws out and yes there is a snap ring there. Just sent for spring loaded pliers to remove. Should pop out now. Thanks for responding
