Homelite UT-20700 weed eater - can't find the correct parts for the head
johnny7
  • / Homelite UT-20700 weed eater - can't find the correct parts for the head
I have a Homelite UT-20700 weed eater and there are parts missing for the head. I thought I ordered the correct parts but when they came, they were completely different than what is on the head.
On the handle, there is a model number: D825SB. When I look that number up, it does not cross back to a UT-20700. Instead it crosses back to a UT15152 or UT15170.
Either way, I can't seem to find the right parts for this unit. I've attached pictures of the head so that you can see what I am referring to.
Get a complete new head
You will need to measure the bolt / hole size ad note is can be mm . in and both come in left & right hand threads
Other than Echo, Stihl, & Shindiawa I have never been able to get the correct parts to repair a worn through/ broken head
The first image tells the story...It is a DIYer rigged job.
You need either a DA03001A (0.080) [ Stens 385-256] head or a DA04591A (0.095) [Stens 385-249] head.
