- Nov 29, 2014
- 64
- 24,745
Have a good look at the carb set up.Nothing to stop fuel under pressure from being pushed out of the main jet and then strait into the cylinder.
Some of the older ones had check valves which were activated by pressure drops in the venturi
However most of them have been deleted over the years.
Very few would get enough pressure to open the metering needle , remember it should have a pop of pressure of around 15 psi and the tank should start to vent around 10 psi
However there are few too many shoulds in that statement and even if the needle is off the seat for a second or two, a lot of fuel can pass through the main jet.
Some of the older 2 strokes had drain plugs in the crank to drain off water, oil & fuel that accumulates in there.
