- Sep 24, 2017
- 252
- 6,458
Siphon effect.Interesting.. As my gas line must flow up to top of tank (where it exits) to then head to gas filter & then electric fuel pump & finally carb..
i use the briggs 698183 shut off. fits 1/4" id line, i usually install it before the filter that way you can shut it off when you change the filter.I am looking to add one to my Timecutter. Which type do you all recommend and should I put it before or after the fuel filter?
Would the Briggs 698183 work on my mower even though it is not gravity fed?i use the briggs 698183 shut off. fits 1/4" id line, i usually install it before the filter that way you can shut it off when you change the filter.
I install 1/4” fuel shut off valves on lots of equipment. It is amazing how old some equipment is, has been to other shops, and fuel shut off never installed.Would the Briggs 698183 work on my mower even though it is not gravity fed?
YesWould the Briggs 698183 work on my mower even though it is not gravity fed?
PS: My OE gas shut-off is at very top on tank. (way before filter)Siphon effect.
Yea, I have yet to see that happen on any of mine. Hopefully it never does either.Siphon effect.
oh belive me, it's not if........but when. Muahahahahaa.Yea, I have yet to see that happen on any of mine. Hopefully it never does either.
The knock offs definitely don't last as long.Ordered the briggs shut off and will be installing it this weekend. Crazy how expensive these little parts have gotten. I could have ordered the knock off for half the price but decided not to because I don't want to risk any leaks.
