Engine size replacement
Rls8836
I have a 2006 Lazer Z with a good running 19 hp. Kawasaki engine. What direct fit larger hp. Engine could I buy that bolts on with the same clutch.
Anything with the same size crankshaft
2 diameters 1" or 1.125"
Only another kawasaki will be plug & play bcause the plugs are all different .
hlw49
post model and spec # and we can help U find the direct fit engine.
