Hello Everyone. I purchased a new Cheetah II 72" with the Kaw EFI back in June of 2021 for residential use. I mow about 5 acres. In 2022, I had my first drive belt failure at about 30 hours. I put a new belt on and it lasted about 10 hours and failed again. I took it to the dealer for service and they couldn't find anything wrong with it. I finished out the season. In 2023, I had two more drive belt failures and took the mower to a different dealer. They said my pulleys were out of alignment and they replaced tensioner bearings and adjusted tensioner height. The mower was at 89 hours. Now, 2024, first cut of the year, another belt failure at 101 hours. The belts are all wearing down width- wise to about half of a new one and the nubs are worn down on the inside. Sometimes they break or just too lose to work. I took the mower to the dealer who repaired it last and this is where it currently sits. The dealer called me and asked me if I store it in a barn with a dirt floor. I said no, I keep it in a 40 foot shipping container. He said "the pulleys look like it sat at the bottom of the ocean for 20 years and all the drive pulleys need replaced" for $1,300. My warranty is up in June but he said this wasn't covered. He was going to make some calls. I called SCAG and they were also going to make some calls and get pictures. I asked SCAG if the pulleys were plated to prevent corrosion. He told me the coating may have worn off because of the alignment issue. Now I wait. I kept my Kubota diesel zero turn in this container for 6 years without issue. push mowers, snow blower and the 46" Cub Cadet tractor from Home Depot I had to buy as a back up when the SCAG breaks down. I know containers sometimes sweat inside but I don't see corrosion on my other stuff I keep in there. Thanks for reading. I'm just really disgusted.
Bernie
