What would be the base settings be for a old Woodshark 14 inch saw? I live at 2500 feet.
F fayjim2 Active Member Joined May 26, 2018 Threads 22 Messages 69 Apr 22, 2023 / Carb. Settings #1 What would be the base settings be for a old Woodshark 14 inch saw? I live at 2500 feet.
I ILENGINE Lawn Royalty Joined May 6, 2010 Threads 39 Messages 10,154 Apr 22, 2023 / Carb. Settings #2 1 turn out on both screws should be a starting point.
F fayjim2 Active Member Joined May 26, 2018 Threads 22 Messages 69 Apr 23, 2023 / Carb. Settings #3 okay I just got in from garage. High was at 1 1/2 and the low was at 4 1/2. Is that a good reason for poor performance. It only ran when throttle was at wide open.; I will try to start today. Thank you
