Hammermechanicman
- Jan 10, 2020
- Threads
- 58
- 3,578
Been swamped for weeks now. Worse than the last couple years and stens taking a week to get parts to me plus half their catalog backordered. Arrrrrrgh.
Well the ATV had the main jet fall out of the carb so that was an easy fix. The Troybilt carb work went fine and was returned to the customer. The Kohler 25 with the blown head gasket has had the gaskets replaced but is running rich and dumping fuel into the oil, so doing a carb repair on it. Have the $5K engine for the SxS but waiting on gaskets since the long block didn't come with them. JD deck shell turned out great but need an idler pulley since discovering that it is causing a deck vibration. Valve cover leak was fixed, still need to go get the one with the PTO issue and can now add one that I have to go get due to a bend blade from hitting roots in the yard. Have another Craftsman Z turn with the Courage twin that came in as a non running and the hydro's won't free wheel. Started out with a bad starter solenoid, which lead to oil fouled plugs, and after getting it running it also is blowing black smoke like the choke is on, but most likely the same issue as the Kohler 25 with leaking fuel into the engine while running.Busy here also, but seems different. Not the normal simple repairs that take 30 to an hour to repair, and complete several a day. More of the less pieces but the stuff where 1-2 pieces is an all day project.
Currently have a Honda ATV that is blowing black smoke after warmup. A Troybilt tiller that needs carb work. A Craftsman rider with Kohler 25 with blown head gasket symptoms. A JD z-turn were the right spindle mounting bolts cracks through the deck shell. Will require a bunch of fabri-cobbling since a new shell is $1K, Currently waiting on the $5K new engine for the SxS that was destroyed due to low oil.
And have a CC waiting on tuneup and valve cover oil leak repair and another with electric clutch issues that I have to go pickup when i have room in the shop.
Should have all that done before lunch.Well the ATV had the main jet fall out of the carb so that was an easy fix. The Troybilt carb work went fine and was returned to the customer. The Kohler 25 with the blown head gasket has had the gaskets replaced but is running rich and dumping fuel into the oil, so doing a carb repair on it. Have the $5K engine for the SxS but waiting on gaskets since the long block didn't come with them. JD deck shell turned out great but need an idler pulley since discovering that it is causing a deck vibration. Valve cover leak was fixed, still need to go get the one with the PTO issue and can now add one that I have to go get due to a bend blade from hitting roots in the yard. Have another Craftsman Z turn with the Courage twin that came in as a non running and the hydro's won't free wheel. Started out with a bad starter solenoid, which lead to oil fouled plugs, and after getting it running it also is blowing black smoke like the choke is on, but most likely the same issue as the Kohler 25 with leaking fuel into the engine while running.
