- Nov 29, 2014
- 65
- 24,809
So if the liquid drain pan over fills or boils & froths up. where does it go ?So I got the new one and took the old one apart. There's NOTHING under the bottom plate but another piece of sheet metal that formed with a gap between it and the floor plate. It's only purpose is to hold two knobs, that are attached to the door mechanism. That's it. Nothing electrical there what so ever.
And under the bottom plate, the outside if you will, is spotless. No rust. No corrosion. Nothing. All the rust and corrosion is on the inside.
onto the crumb tray ?
