2000 walker mower, carburetor, linkage and diagram
Lionel762
  • / 2000 walker mower, carburetor, linkage and diagram
2000 MCSD 16 hp. I need some help with the carburetor linkage. I had it off for a small repair and when putting it back on, it’ll only run at high idle.
I can send pictures, or maybe where I can find diagrams
Needed more than pictures are all engine numbers. Can’t help much unless we know exactly what engine you have. Pros on this forum hate making guesses like the DIY guys.
Lionel762
I assume that. Where will I find that number?
Lionel762
Thank you. Mower has been sitting a while and covered on dust. Where is the tag with numbers located?
Depending on what engine you have they can be found in different locations. Briggs will stamp them on either the valve covers or engine shroud. Kohler and Kawasaki use an ID decal.
Lionel762
It is a 16hp Kohler. Thank you again For the info and your time.
You will need to narrow down your engine to which of the hundred different 16 hp engines Kohler built. Look for a black and silver tag on the engine cover which contains engine numbers.
Lionel762
Unfortunately, I am not able to find a tag or model number on the engine. There is a plate above the carburetor that I removed. It says Kohler 16 hp V-twin. In the pictures I’ve attached there is a small plate on the backside of the motor right side that is clean and I wonder if the information was in ink and cleaned off? Were they stamped?
Pictures will not load. I’m open to any other suggestions. Thank you again.
Lionel762
As I was sending the last reply I thought, “I wonder if there is anything in the manual?”
Sure enough. Here is what I found.
Tractor model: MC52 SD
Engine Model: TH-165
Engine replacement: ch621-3012
