golfcartNF
- Mar 4, 2024
- Threads
- 2
- 11
Okay so I retested this and found that the guy I had helping me had his probe on the negative terminal while I tested the voltages at the key switch. Here are the correct voltages for the A, I, and R terminals.Terminal A key in off position: 0v
key in on position: 2.2v
key in run position: 0v
Terminal I key in off position: 0v
key in on and run position: 2v
Terminal R key in off position: 0v
A: off - 12.5v
on - 10.5v
run - 12.5v
I: off - 12.5v
on -10.7v
run - 10.7v
R: off - 12.5v
on - 10.5v
run - 10.5v
