pahanorlando
- Jun 3, 2022
- 1
- 3
Hello all. I just purchased Gravely ZTX-42 with 591 hours on it.
One side goes faster than other, which means it'll probably need some adjustments on levers or by the transmission.
But I was wondering, since it has that many hours, is it worth replacing the oil? I know that usually they do not go bad, but at the same time, can't it go bad because of old used oil? I'd rather replace oil than replace transmission parts.
Some say if its running fine don't change it, but couldn't it be a good preventative maintenance?
I know it's sealed and removal of transmission will be needed to drain the oil.
Thanks
Thanks
