ZG 222 needs more horse power
Richard 54
Hi all, I have a ZG 222 , which is 22 hp when running the mulching kit it struggles.
the Zg 227 of course is 27 hp ,
does anyone know how to bump the zg222 up the 5 hp , I’m a bit stumped as the motors are identical right down to the carburettor , camshaft etc (same part numbers) any help would be helpful.
Usually the Hp difference is nothing more than a restrictor between the manifold & the head
Some times they are thin metal plates other times they are just a gasket which has a smaller throat hole.
Back in the "god" they used to change the main jets as well but in the era of the EPA that is no longer done.
Other than that it is just the sticker on the engine cowl.
No law about understating the Hp.
However if the 22Hp is struggleing then the 27Hp probably won't make a difference
There is an absolute limit to how much grass can be held up in the air getting recut by a mulching deck
Usually the big problem is taking too bit a cut .
I am yet to see a mulching deck that can handle more than a 3" cut.
We have just had a very rainy month followed by some days pushing 40 C .
I have a list of belt replacements longer than my arm and the phone just keeps on ringing because the local mower shops can not get belts in before christmass & they know I keep a big inventory.
All of these are because owners have overwhelmed the capacity of their decks to the point that the belts broke.
I can tell them to take smaller cuts but they all reply that they don't have the time to cut the grass more than once a week .
So they wait 4 days for a new belt by which time the grass has grown another 4" to 6" which they try to remove in one hit & brake the belts again
A mower can only do what it is designed to do regardless of how much time you have or the need to cut grass that is 10+" tall
Richard 54
You where right there was a plastic plate between the carburettor and the manifold that was restricted,opened the holes up with a die grinder. has made a world of deference, have no trouble mowing with the mulching kit now in a normal situation.
lugbolt
Now you will want to change the oil a little more often. The ZG227 is the same exact engine, but with a different sized restrictor plate. BUT-it also has an oil cooler because the engine has more power, and makes more heat, and Kubota saw it fit to cool the oil which cools the engine. Keep a close eye on the flywheel screen too as it is in a place that nobody ever thinks about, and it gets dirty down there-quickly. I've seen many a ruined engine because of it.
