Z540M Blade ?
beretta22
I have the blades that came with the mower (M143520). Just wondering if the high lift blades, or, mulching blades would be any better? Would like to find one to cut up leaves better than what I have.
D
Deleted member 97405
Guest
If you're not installing a mulch kit, don't install mulch blades. They don't create much lift and will leave your grass looking like you cut it with a weedwacker. If the regular blades aren't pulling the leaves up from the grass, install the high lift blades because they create more suction and thrust. Another trick is to blow your leaves in a row and back over them with the blades running. This will grind them up more. Just be careful the leaves arent piled too high because you don't want to drag your muffler through them and start a fire.
D
Guest
My catalog shows high lift blades available for the 54" mower deck. They are M152726.
