Hello I have a z425 was running fine, shut it off and when I came back to finish it won't start. Nothing when you turn the key, doesn't turn over. It will start if I jump to the starter just fine. No power to the solenoid via purple wire, no power to left, right or parking brake switches. There is power to seat switch, hour meter and pto (it clicks when I pull it on). Changed relay, replaced ignition switch, checked wiring and can't see a break. Any ideas would be greatly appreciated. Ordered a pto switch
