I have a husqavarna Z254 zero turn. Recently it has started to intermittently lose speed. It doesn't matter if it's full throttle or if the blades are engaged or not. It will be going full speed and slow down to a crawl without the RPMs changing at all. It might go on for 30 seconds or so and go right back to normal speeds. Can't identify any pattern. Any ideas?
