Z125 starter doesn’t crank on restart attempt after hot.
isoguy
  • / Z125 starter doesn’t crank on restart attempt after hot.
Got a 2014 (400 hrs) 125z with Koehler engine. For quite awhile, I have an issue on restarting the engine after mowing long enough for the engine to get hot. The engine won’t turnover at all (battery is good). All I get is a solenoid click. After sitting for a couple hours (Cooling off) it will start right up. Not a fuel system issue. Strictly ignition/electrical.
mechanic mark
Your engine is overheating due to engine cooling fins on cylinder heads need to be cleaned by hand, also check air filter for replacement. Remove blower housing, top cover over engine, clean all dirt & crud from engine cooling fins with piece of coat hanger wire, etc., I use a shop vac to vacuum all the crud up. Take your time cleaning engine thoroughly, shop towels & rags work well. Your engine will be able to breathe & run cooler. Let us know if this helps, thanks, Mark
Hammermechanicman
Pull a spark plug and take a pic and post. Will tell if engine is running too hot. When it won't start jump the 2 big terminals on the starter relay or solenoid, depending on whether you have a solenoid on the starter or a separate relay. If you jump the terminals and it doesn't crank how hot is the starter to the touch? So hot you can't leave your hand on it? If so engine is running too hot. If starter cranks engine then relay/solenoid or wiring problem. If starter not hot and no crank bad starter.
lugbolt
hot running isn't usually an issue with the Z125.
I have seen and experienced this on my ZG127 which is almost identical.
Kohler. Stupid Kohler. I hate Kohler. But I have a Kohler and am looking at putting a Kawasaki on it.
Anyway....there are two possibilities. One, starter is failing. Not uncommon on Kohler, particularly the SV840's. With that said Kohler updated their replacement starters. They have about 40% more torque, and the main shaft is considerably beefier. It cranks faster, quieter, and lasts. There is also the chinese replacement starter option which I am not a fan of. I've had like 7 or 8 or 9 of them, they never last very long--but in my case, they have warranty so I keep replacing it. I think I have a spare too just in case. What causes the starter to fail? #1 cause is lack of maintenance. Valve adjustment. The Koher needs it's valves adjusted once in a while. When the clearance opens up (which is normal wear characteristic), the compression release fails to release enough compression, the pressure jumps way up, and the starter won't turn it over--a lot of times it will break the old-style sharter shaft completely off. Seen that once on mine, a bunch of times when I worked at the dealer.
Another possibility is the relay is failing. I had to replace a bunch of those too. If you do, the torque spec for the two nuts that hold the cables on, is 4 inch pounds. Snug. not tight just snug. If you overtighten it it will fail again. Guaranteed.
possibly a safety switch issue too. Has it been updated? New style brake switch? Call dealer and ask them if it's been updated, they can look up the serial number. They had a massive repair campaign dealing with it, but it is expired by about 2 years now, so if yours hasn't been updated, you get to buy it and install it...or pay the dealer...and it's pretty involved, they have to replace the crossmember under the fuel tank, which means a lot of disassembly. I did a bunch of them and after while began to hate them!
