YTH24V54 Carburator Part number ..
SESZOO
Haveing trouble finding the right carburetor for my yth24V54 ,Briggs and Stratton Intek V Twin mower Model #44N877, The # on the carb is 593199 . but every time I enter the info It comes up with a # 791230 which isn't the carb on it . Any ideas on who might sell them now a days Thanks Tryed uploading the image but guess it's too large.
Scrubcadet10
Moderator
Staff member
according to briggs, that model uses 594530.
If you can post up the rest of the model number (type number) (44n877-xxxx-xx), to be sure they didn't change carbs at some point or another.
The PN on the carburetor has no relationship to the actual carburetor PN. It is the base carburetor PN (in house PN) that Briggs orders and then modifies to the particular engine spec. requirements. As Scrub said we need the model and type numbers to look up the correct carburetor. And even then we might need the date code too as Briggs does change specs sometime during the engine manufactured life.
SESZOO
Thanks . for the info
