YTH2348 Starting issue
Bbentley40
Hi all, I just bought a used YTH2348 with a starting issue, so I am trying to diagnose it before I start replacing parts. When you turn the key the engine will click and hum like it’s wanting to turn over but doesn’t. If you keep bumping the ignition to the start position it will eventually start. Not sure if I should start with the ignition switch, solenoid or starter.. so thought I would see if anyone else has had this issue. I have a small video of what it’s doing, I can work on getting it uploaded or email it to anyone who might can help.
Thanks!
Bbentley40
Here is a video of the issue, I just loaded it to youtube so I could share it.
Take the plug out and try again.
Engine spins rapidly every time = decompressor problem
Liquid fuel blast out of plug hole = carb float problem
No change = electrical problem
Run a jumper directly from the battery + to the starter motor.
motor spins quickly = solenoid or heavy solenoid wiring problem
No change then run a jumper from the battery - to the drain plug ( or other good ground near the starter.
Starter spins freely = ground connection problem
no change = faulty starter.
Some starters have rebuild kits for the brushes some don't.
Bbentley40
Excellent.. I will run down that list tomorrow after work. Thanks!
Luffydog
Sounded like the starter spinning and then caught then started. Like the gear is bad
Boobala
I think after performing the earlier mentioned test's are done, you will most likely find a valve adjutment is called for...
Bbentley40
I checked it this morning before work and yes it sounds like the starter is spinning (thats the humming sound I was referring to) but the engine does turn over. After bumping the key a few times the engine will catch and turn over. Soon as the engine turns over it starts up and runs fine.
Bbentley40
Finally had a chance to test some things. At the end of it all it was the starter pinion. It had worn to the point that the threads inside of it would not allow it to freely spin up the shaft. Bumping the starter over and over just happened to get it to eventually spin up. Replaced the pinion and it fires up like a champ now! Engine surges a little.. I am sure the carb is dirty. I am going to tear it down and clean it next. Here is a pic of the gear I swapped. You can see the wear on the threads. B50F9EE7-8044-478F-9B24-3F0854769108.jpg6D273DA5-9FD8-4BC6-BD07-5FDD753677A2.jpg
