Yth2148xp blade problem
Ejay90
Hi all. I have a Husqvarna YTH2148xp with blade issues.
I hit a greywater hose on the property a while ago and two of the three blades stopped working. One is still cutting grass perfectly fine. Took it to the local mower shop where they weren’t interested in fixing it. Told me it was due to issues with the electric clutch and not to bother fixing while trying to sell me a brand new ride on. Would this be correct? Surely if issues with clutch - all 3 blades would stop spinning?
I’m picking it up tomorrow to start working on it myself. Any advice would be appreciated!
I would assume that the right blade is still working. I am leaning toward the lower deck belt has either broken or jumped off the pulleys and is not longer spinning the other two blades. There should be a belt from the electric clutch to top of a double pulley on one of the blade spindles and then another belt that goes from the bottom of the double pulley to the other two blade pulleys
