YTH18542 Brake question
T-Roy
Just purchased new YTH18542 2 weeks ago. Started it for the first time today. I noticed the brake pedal slightly moving while the motor was at idle and a noise that was in sync with the pedal movement, sort of sounded like it was slightly engaged. However, if the pedal was depressed about an inch or so, the pedal movement and the sound disappeared. Is this just a natural occurance with this being a new mower or does something need adjusted? I would appreciate any suggestions.
Thanks!
Luffydog
Check the drive belt parts plus the pulleys. Might have a very slight vibe to them but not a lot.
