PTmowerMech
- Apr 16, 2018
- 393
- 3,007
With the deck belt the right length, the pulleys being in good shape and the right size, and everything seemingly in working order, you just gotta go with a shorter belt?
I've double checked the pulley's and they're right. I pulled the bracket (that holds the PTO cable in place) back to remove some of the slack. In fact, the blades still turn a little with you disengage the belts now.
But customer just called and said the belt came off again. I engaged and disengaged it about 20 times before I took it back.
THE only thing I didn't check to see if it was the right length, was the PTO cable itself. But when I engage the belt, it tights up.
