yt16h drive
saminmn
I have a 89 YT16H that the trans seems to be slipping. I have changed the fluid and put on new belts. They are all tight & every thing seems OK. Sometimes its ok when I first start out but it gets worse as you go along.Any suggestions? saminmn
mechanic mark
Please post all numbers, model #, serial #, engine numbers, etc.
http://www.messicks.com/NH/51489.aspx
http://www.ssbtractor.com/tractor_m...anual_make=Ford&tractor_manual_model=09GN2199
Thoroughly inspect first, everything hands on, have another mechanic assist you.
I would first make sure it's the transmission and not differential [ rear end ] etc. if applicable. If you find it is transmission, I would drain it, remove trans., disassemble, inspect for worn or broken parts, order necessary parts. You might want to purchase service manual, make sure it includes transmission.
saminmn
Mechanic Mark- It's a 1989 B & S, Model # 402707 YT 16H Yard Tractor Model 09GN2199
Type-1401-01-89022012 Component #9607481
Code-89022012 Serial # YC0110-90741
16 hp Twin II
Industrial/ Commercial
Cast Iron
Thanks for reply! saminmn
